Regulator v Regulator / Rectifier
KwackerNut
#1 PostAuthor: KwackerNut » Fri May 25, 2012 9:21 pm
Can anyone advise on changing from a Regulator to a Regulator / Rectifier.
Following a problem starting the bike, i charged the battery up and found the charging voltage went from 13.7 to over 17 volts at about 4,000 rpm - Regulator problem.
Z Power advised the regulator is no longer available, and i now have a nice shiny Regulator / Rectifier with the same Green Plug, a black earth and a white wire, which i think should be connected to the white wire that was connected to the standard Rectifier unit ???
Question is, what do i do with the White plug, now that its function has been replaced with a combined unit? Is it OK to just remove the old rectifier and leave the white plug blank?
Any advice would be appreciated.
Jim
Far away across the field,
The tolling of the iron bell,
Calls the faithful to their knees
To hear the softly spoken magic spells.
z1000puddin
#2 PostAuthor: z1000puddin » Fri May 25, 2012 9:28 pm
I blanked mine off with a heat shrink cover
Zed til Dead
KwackerNut
#3 PostAuthor: KwackerNut » Fri May 25, 2012 9:37 pm
I will take that as, Yes, its OK to just remove and forget.
Great service we get in this club, 7 minutes for the answer, top stuff.
Jim
jimmock
#4 PostAuthor: jimmock » Sat May 26, 2012 11:56 pm
KwackerNut wrote:Thanks
Jim
My wife says I'm much quicker than 7 minutes!!!
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
Garn 1
#5 PostAuthor: Garn 1 » Mon May 28, 2012 9:40 am
KwackerNut, just for interest, both the green and the white plug are wired the same. So, either would do to connect to the Rect/Reg combo. As Puddin says, it is a good idea to blank off one of them or just disconnect the single rectifier.
RegardZ.
KwackerNut
#6 PostAuthor: KwackerNut » Tue May 29, 2012 6:41 pm
Cheers Garn
Have done a few trips on her now and she seems to be OK.
Will make sure the white plug is blanked, as i have removed the single rectifier unit.
Voltage across the battery goes from 13.5 to about 14.7 at 3,500 rpm and above, which I thought was a bit high. Any ideas, or is this standard?
Jim
sweptail
#7 PostAuthor: sweptail » Tue May 29, 2012 10:35 pm
Checked voltage across battery meself `tother day. 14.7 at 4000rpm with lights off. Anything below 15 is fine.
KwackerNut
#8 PostAuthor: KwackerNut » Wed May 30, 2012 8:56 pm
Thanks Sweptail
Always good to get a second opinion.
Jim
