Convert from Cam cap bolts to studs
nanno
#1 PostAuthor: nanno » Mon Jun 18, 2012 6:43 am
I know there used to be a thread on this forum, but for the life of it... I can't find it.
What I want to do is to convert my Z1000J cam cap bolts to studs, because even after fixing them with helicoils, they are not 100% confidence inspiring to be honest.
Cheers,
Greg
#2 PostAuthor: kev edwards » Mon Jun 18, 2012 10:33 am
Hi Greg' i am the guilty party for this mod, i done it on my old nail about six years ago and the bike is still going strong, another member owns it now, there is a small write up on how i done it in this link i believe i still have a set of studs that will need to be tailor fitted to a head if you need them, i will also advise you where i can if you do this mod.
http://www.z1ownersclub.co.uk/forum/vie ... ht=#151699
[IMG]
the studs i made up.
this is another head insert for use with cam cap location i made for Mr puffin and as far as i am aware is also holding out well.
nanno
#3 PostAuthor: nanno » Mon Jun 18, 2012 6:08 pm
Hi Kev,
that's a very kind offer, if you happen to find them, I would be more than delighted.
If not, it's not that bad, as I have a lathe and then I will just turn down a set of M8-bolts to 6mm and cut a thread.
Cheers,
Greg
