Running great [Except]
zman
#1 PostAuthor: zman » Wed Jun 20, 2012 10:25 am
The good news.The bike ticks over very well.And she rides great :)
But after rebuild she been running a bit rich[very dark brown] but did not bother me as she rides so well.But ive noticed she pops abit when you are of the throttle and the plugs are getting a bit sooty.Apart from that runs like a dream but like to sort it.
This is what i have checked.Carbs are z1000 26mm
Not sure if jets are correct.got a gunson but cant see much change when adjusting.The adjustment is a mixture screw not air but is the same difference yes:?:
got 11volts at the coil.would 1volt drop make the difference :?:
keep thoses wheels turning
Keefleaf
#2 PostAuthor: Keefleaf » Wed Jun 20, 2012 10:36 am
"Popping" can be caused by air leak in exhaust system,should coke up / seal with use.
gray
#3 PostAuthor: gray » Wed Jun 20, 2012 8:31 pm
A gunson will be best for checking the mixture at idle - and the air screw will adjust that, at that engine speed,if the passages are clear and the float heights OK.
A gunson's not so good for checking mix at full throttle or half throttle - Dyno might be better , or an old fashioned plug chop
gray
#4 PostAuthor: Pigford » Wed Jun 20, 2012 9:14 pm
Popping could be leaking rubber manifolds - check seating & for cracks, etc :wink:
