leaking exhaust
zman
leaking exhaust
#1 PostAuthor: zman » Wed Jun 20, 2012 12:56 pm
how do i check to see if the exhaust is leaking :?:
keep thoses wheels turning
#2 PostAuthor: z1bman » Wed Jun 20, 2012 1:13 pm
START THE BIKE + BLOCK OF THE END OF THE EXHAUST WITH SOME CLOTH + LISTEN FOR ANY LEAKS AROUND THE DOWNPIPES WHERE THEY CONNECT TO THE HEAD. ALSO UNDERNEATH THE ENGINE IF YOUR DOWNPIPES ARE NOT WELDED TO THE MAIN PART OF THE EXHAUST. A GOOD FITTING EXHAUST SHOULD STALL THE ENGINE IF THE END OF THE SILENCER IS BLOCKED OF
gray
#3 PostAuthor: gray » Wed Jun 20, 2012 8:26 pm
Listen for blowing
feel (carefully) for a draught of gas,
look for sooty deposits
Might backfire too when closing the throttle
gray
