swing arm bush conversion
wayno
#1 PostAuthor: wayno » Sat Jun 23, 2012 2:09 pm
i bought this conversion kit for a swingarm but the instructions are in german, just to be sure i thought i has better ask on here which way the 2 washers on the outside of the new tube , this sticks out about 5 mm or so either side, one washer has a bit in the middle that rotates the other is a plain one.
http://www.z-fever.de/ShopNeu/shop/show ... cts_id=539
#2 PostAuthor: z1bman » Sat Jun 23, 2012 3:42 pm
the flat washers are fitted to the end of the shaft. one either side. then the dished washers fit over the top on the outside
wayno
#3 PostAuthor: wayno » Sat Jun 23, 2012 6:57 pm
thats what i thought, but now they have arrived the ones in the pic that go on the inside are only just smaller in diameter than the dished ones, the pic looks like they would sit over the inners but dont. will have to try in the frame when i get it back on mon.
cheers wayne
