MK11 ROTOR
KeithZ1R
MK11 ROTOR
#1 PostAuthor: KeithZ1R » Sat Jun 23, 2012 4:49 pm
Due to some gross buffoonery during the simple task of repairing a starter clutch I now require a Mk11 rotor housing as the magnets that were!! in mine are now attached to every fecking metallic object in the garage :oops: :cry: anybody help please :?: apparently Mk11 ST or any of those engines are the same
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
compo z1r
#2 PostAuthor: compo z1r » Sat Jun 23, 2012 7:54 pm
pm sent
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
KeithZ1R
#3 PostAuthor: KeithZ1R » Sun Jun 24, 2012 1:40 pm
ok anybody got any ideas where I might find one then ?? or any possible substitutions although the crank taper is considerably bigger than the earlier engines
Keith
:bop :gom
mistaken.
Hobbo
International Rep
yo
#4 PostAuthor: Hobbo » Sun Jun 24, 2012 2:16 pm
International Rep
KeithZ1R
#5 PostAuthor: KeithZ1R » Sun Jun 24, 2012 2:20 pm
yep seen that thats the last resort
Keith
:bop :gom
mistaken.
compo z1r
#6 PostAuthor: compo z1r » Sun Jun 24, 2012 4:32 pm
KeithZ1R wrote:yep seen that thats the last resort
:lol: ouch :lol:
#7 PostAuthor: chrisu » Sun Jun 24, 2012 5:44 pm
eek !
KeithZ1R
#8 PostAuthor: KeithZ1R » Mon Jun 25, 2012 3:54 pm
Eek! Indeed :shock:
Keith
:bop :gom
mistaken.
#9 PostAuthor: z1bman » Mon Jun 25, 2012 4:13 pm
i am sure you could modify another rotor from a Kawasaki if you know what the dimensions are. most of the z1000s of that period use the same stator+ i think the only difference in the rotors is the taper ? which is riveted to the rotor. if you can find one with the same dimensions it shouldn't be that difficult to remove the centre of your old one + re rivet it to the replacement. it might be a good idea to ring electrex world + enquire if yours could be repaired with some new magnets
DavidZ1R
#10 PostAuthor: DavidZ1R » Mon Jun 25, 2012 5:01 pm
Hi Keith, not sure but is this what you are after?
http://www.ebay.com/itm/Starter-Clutch- ... es&vxp=mtr
#11 PostAuthor: chrisu » Mon Jun 25, 2012 5:40 pm
Will a J one fit?
Electrex do them for £120
KeithZ1R
#12 PostAuthor: KeithZ1R » Mon Jun 25, 2012 7:26 pm
David thats the early style thats predominate across the range The one we want has the magnets in a kind of bell housing Z1bman yep that was an option as well as the rotor taper seems to be the issue only and i could have had it re-populated with magnetic material Chris the j unit reverts back to the smaller crank taper .... However it seem you only really need to know where to look :wink: Im sorted now thanks everybody ....... Oh and another important lesson learnt and not only by myself over the years apparently :D
Keith
:bop :gom
mistaken.
