What front end to go for?
IanM63
#1 PostAuthor: IanM63 » Tue Jun 26, 2012 10:10 am
Ok, I need a front end for my 900, what do you recommend?
I'm looking for modern (ish), 3.5inch three spoke rim, not fussed if it's USD or not. Which models are long enough? Fit easier etc..
steve bowdler
#2 PostAuthor: steve bowdler » Tue Jun 26, 2012 11:19 am
IanM63
#3 PostAuthor: IanM63 » Tue Jun 26, 2012 12:33 pm
Thanks for that Steve. Some good info there.
sanderz
#4 PostAuthor: sanderz » Tue Jun 26, 2012 10:05 pm
steve bowdler wrote:http://www.z1ownersclub.co.uk/forum/viewtopic.php?t=17077&highlight=forks
http://www.z1ownersclub.co.uk/forum/vie ... ight=forks
Have a read of these threads may give you some idea
Valuble info there :up
Think anything can be 'made to fit' but at what consequence - as mentioned in those posts, ie limited lock, altering rake/ trail which could lead to billet yokes etc.
Down to budget in my book and i would favour 'right way up' forks and look for a complete front end if possable - forks, yolks, wheel and discs.
This can save a lot of adapting / running around for parts.
I've FZR Genesis forks / yolks on my Z1 - 41mm dia, length is 780mm approx to spindle, yolks have different bearings to suit frame but steering lock is errr 'limited' :roll:
Hope this gives you some ideas
Wots up DOHC
sanderz
#5 PostAuthor: sanderz » Wed Jun 27, 2012 7:01 am
Thought these could be of use to yer as well -
http://www.oldskoolperformance.com/foru ... =10&t=1659
Fork lengths sizes shown
http://www.z1ownersclub.co.uk/forum/vie ... hp?t=20498
Bearing dia for headstock.
Wots up DOHC
750steve
#6 PostAuthor: 750steve » Wed Jun 27, 2012 8:51 am
Im gonna be using ER6 forks (RWU items) on a Z650 build. The forks are about the same length as the std ones on the 650. I'll have to pres the stem out & bush it out to fit the ER6 Triple Clamps
