Master cylinder boring 1/2 to 5/8
gbh
#1 PostAuthor: gbh » Sat May 06, 2006 10:34 am
Can anyone recommend a business that can bore or resleeve the stock 1/2 single disc Z1 master cylinder to the larger 5/8 bore that was used with the twin disc front?
I have 3 master cylinders that I want done. I have found a company that can replate in the original Alumite finish at a reasonable price and would like to make the job worthwhile by refreshing completly instead of sticking with the 1/2. Any suggestions?
Thank you.
Davy Doherty
#2 PostAuthor: Davy Doherty » Sat May 06, 2006 11:37 am
I've asked that very question here before George with no luck, although i think Rick Brett does it on an exchange basis, Paul has a friend who was able to do mine for me with no problem's,
#3 PostAuthor: paul doran » Sat May 06, 2006 4:15 pm
Davy I still have that contact if needed
000zeds
#4 PostAuthor: 000zeds » Sun May 07, 2006 12:20 am
I think Chris Rivett does it but better contact him first.
#5 PostAuthor: paul doran » Sun May 07, 2006 12:29 am
Dave my friend will do your own master cyclinder for about forty euro's which is about twenty pound's
I don't think anyone will better that
(Edited by paul doran at 1:30 am on May 7, 2006)
gbh
#6 PostAuthor: gbh » Sun May 07, 2006 8:51 am
Thanks Paul, do you have a contact email address I could have to contact your friend?
#7 PostAuthor: paul doran » Sun May 07, 2006 12:32 pm
I will get his email address George
He made a jig for holding the master cyclinder in and then put's it into the lathe
this bloke is a qualified engineer and is brilliant at fabrication as well
the thing's he can reproduce in aluminium are great
