Need to get it off to get rechromed
Z1000 A1 A2 rear hub disassembly
- spondonges
Does anyone know how to take off the steel chrome plated spoke ring from the rear hub (spoked wire wheel) ??Is it an interference fit or is there a screw fixing hidden in it somewhere to release it??
I'd rather be riding my Z1 thinking about God than sitting in a church thinking about my Z1..
- Mark Tiller
These are impossible to remove. I have tried heat, freezing - nothing will budge them. You could clean it up a and spray with a chrome finish.
they can be removed but it is not a DIY job i had one removed years ago by a local engineering company who specialised in manufacturing old British bike crankshafts. they removed it with the use of a 50 ton press. they had to make a support to fit on the inside of the hub so the the chrome ring was supported then the hub was pressed through the chrome ring
- spondonges
z1bman wrote:they can be removed but it is not a DIY job i had one removed years ago by a local engineering company who specialised in manufacturing old British bike crankshafts. they removed it with the use of a 50 ton press. they had to make a support to fit on the inside of the hub so the the chrome ring was supported then the hub was pressed through the chrome ring
Definitely not a DIY job
a1/a2 rear spoke plate
yeh iv recently tryed to remove one
in the end up i powder coated it with chrome silver ! looked well smart
