Stiff fuel tap
DavidZ1R
Stiff fuel tap
#1 PostAuthor: DavidZ1R » Wed Jul 25, 2012 7:14 pm
Ant help here, the fuel tap on my Z1R is so stiff to turn, worried I might snap the lever at times, cleaned it out last week, put on new O ring put a touch of grease on the O ring put back together, fine nice and smooth, week gone by stiff to turn again? is it the modern fuel?
compo z1r
tap
#2 PostAuthor: compo z1r » Wed Jul 25, 2012 7:21 pm
in a word YES :wink:
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
KeithZ1R
#3 PostAuthor: KeithZ1R » Wed Jul 25, 2012 8:22 pm
try backing the holding/guide screw a wee bit see if that helps
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
pertonpc
#4 PostAuthor: pertonpc » Wed Jul 25, 2012 9:25 pm
I think not fuel,
My original (1975) Z1 fuel tap was a little stiff to turn up to reserve setting but ok between on and off.
Fitted new genuine fuel tap - much smoother action between all positions.
Fuel did not change.
Conclusion - it's a wear thing. Will monitor and see how long new one takes to go stiff.
From Mark
compo z1r
#5 PostAuthor: compo z1r » Wed Jul 25, 2012 9:35 pm
pertonpc wrote:I think not fuel,
From Mark
i thinks so lead was a wonderfull lube :wink: bring back 4 star :D
#6 PostAuthor: z1bman » Wed Jul 25, 2012 9:40 pm
have you checked the condition of the screw that holds the lever to the tap as this normally wears + causes the lever to sit slightly of centre + bind on the outer edge of the tap
Kev1R
#7 PostAuthor: Kev1R » Wed Jul 25, 2012 10:03 pm
For my Z1r, I have owned 2 fuel tanks for years -
Sometimes I use the smaller tank, as I prefer the appearance - and sometimes I fit the larger tank - usually for longer journeys.
The fuel tap on the smaller 3.1 gallon tank has, from new, always been a swine to turn.
The smaller tank also has a physically smaller tap which exaggerates the problem, as it gives you less leverage.
The larger 4.5 gallon fuel tank (which I am currently using) has always been silky smooth in operation. This is my most 'recent' tank which I have had since 1987.
I always thought this issue was just inherent in the small tank tap design.
#8 PostAuthor: kev edwards » Thu Jul 26, 2012 7:51 am
This may or may not help but could it possibly be the O ring not be made of the correct material and the ethanol has made it expand? Food for thought.
jonhunt
#9 PostAuthor: jonhunt » Thu Jul 26, 2012 8:56 am
Had this problem when I first got my Z1a. Fitted a new tap 10 years ago. No problems since. Its probably worn out. As far as the o rings go if the part is the wrong rubber it will swell in fuel.
scott
Junior Section leader
#10 PostAuthor: scott » Thu Jul 26, 2012 9:14 am
A pingel will sort all the problems out
#11 PostAuthor: ADRIAN H » Thu Jul 26, 2012 6:23 pm
scott wrote:A pingel will sort all the problems out
+ 1, fit a pingel and forget about it.
Bongoball
#12 PostAuthor: Bongoball » Thu Jul 26, 2012 8:54 pm
Fitted a Pingel HiFlow on my Z650.
What a beautifully made piece of kit!
Definately improved performance too.
Go for it!!! :lol:
"Keep on Rockin'!"
