Are Z1100ST cases the same as Z1000J cases ?
nanno
#1 PostAuthor: nanno » Thu Jul 26, 2012 2:41 pm
I.e. could mount all my Z1000J bits into an empty Z1100ST case and convert it to chaindrive along the way with the pieces from my Z1000J ?
On my Z1000J engine two bearings have spun in their seats and the cases are showing the signs of about 100.000kms and a lot of neglect/abuse from the pre-owners.
Cheers,
Greg
big green bus
#2 PostAuthor: big green bus » Thu Jul 26, 2012 5:32 pm
Almost sure you can I have a shaft motor I intend to change to a chain drive. I am sure another member will confirm this (or not :roll: )
#3 PostAuthor: z1bman » Thu Jul 26, 2012 5:53 pm
cases are the same as a Z 1000 csr which is a chain drive machine u will need to replace the output shaft + relace the front bevel housing for the transmission cover that is fitted to the chain drive model
Big John
#4 PostAuthor: Big John » Thu Jul 26, 2012 6:10 pm
My Z7/11 has Z1000ST crankcases with chain drive conversion with a1089 top end.
nanno
#5 PostAuthor: nanno » Thu Jul 26, 2012 6:37 pm
Ok, thx for the info. As I wrote in my first post, I have a complete Z1000J engine, but the cases are a bit tired and a friend has some leftovers from his Z1100ST, so if it is just a case of swapping bits from one engine to the other...
THX
Greg
