KZ900 A4 Double Disk Conversion
david edgcombe
Have been patiently buying up bits from ebay to fit a second disk to the KZ, after much research in various manuals managed to get a second 296 mm x 6 mm 4 hole disc, 4 way dist block, RH caliper and a master cylinder, I can confirm that they are all original Z900 bits, except the master cylinder that is a 'Tokico Japan' unit but not stamped 5/8 as it should be if its the double disk unit. Does any know an easy way to confirm it's a 5/8 unit without stipping it down and measuring the bore? I can can get a new 5/8 unit from Z-Enterprises but trying to save the ? !!
- z1bnackerkwacker
Re: KZ900 A4 Double Disk Conversion
david edgcombe wrote: except the master cylinder that is a 'Tokico Japan' unit but not stamped 5/8 as it should be if its the double disk unit.
Had a similar conversation with Z Power Dave and he told me they are not always stamped 5/8 on bottom......
phil churchett
david edgcombe
