reg/rec wiring[pictures] SORTED
zman
#1 PostAuthor: zman » Mon Aug 13, 2012 1:08 pm
Conected 2xred to +12v 2xgreen to earth and black to point old brown went. does not work.any idears. thanks
keep thoses wheels turning
#2 PostAuthor: chrisu » Mon Aug 13, 2012 3:29 pm
is this for a combined reg/rec for a Z1/z900/z1000 ?
if so it doesn't sound right
you should have 3 yellow wires, a red/white (or red or brown depending on supplier) and a black - some also have a switch wire.
3 x yellow wires - feed from alternator - should get 6-7v off each of them.
red/white - goes into loom - connect to battery side of the switch.
black - earth wire - connect to frame.
zman
#3 PostAuthor: zman » Mon Aug 13, 2012 4:19 pm
Its from a cx500 which was recommended as an alternative
#4 PostAuthor: z1bman » Mon Aug 13, 2012 5:40 pm
green wire to regulator on a H**** is earth. red/white is 12 volt feed from battery. what bike are you fitting it to?
zman
#5 PostAuthor: zman » Mon Aug 13, 2012 5:46 pm
fitting it to z900.replacing a nakered reg/rec.old one had red/white,black and brown
#6 PostAuthor: ADRIAN H » Mon Aug 13, 2012 5:58 pm
#7 PostAuthor: z1bman » Mon Aug 13, 2012 5:58 pm
connect your green wires go to the black wire or direct to earth. the brown wire on your old unit is a switched 12volts when the ignition is tuned on + the white with a red stripe is a permanent 12 volts from the battery . on the new unit are there 2 red wires or has one got a trace colour/ stripe?
#8 PostAuthor: z1bman » Mon Aug 13, 2012 6:02 pm
ADRIAN H wrote:not sure if this will help. http://www.beezeees.com/resources/regre ... .aspx.html
that's the one he should have bought instead of messing about with H**** rubbish they are worse than the Kawasaki ones
PAULJAC47
#9 PostAuthor: PAULJAC47 » Mon Aug 13, 2012 6:06 pm
http://circuit.wiringschematics.net/vie ... 17847h.jpg
Nowt wrong with H**** units used one or two,been using the cheapo ones off ebay recently £29 work fine!
Red white is the feed into the battery the brown wire is the trigger live, 14.6 volts dc at 2.5 k revs if all well...
Re: reg/rec wiring[pictures]
#10 PostAuthor: z1bman » Tue Aug 14, 2012 4:26 pm
zman wrote:Conected 2xred to +12v 2xgreen to earth and black to point old brown went. does not work.any idears. thanks
you should have 12 volts a the red/white permanently + 12 volts at the brown only when the ignition is on.make sure your green wires are going to a good earth = black/yellow on kawasaki. have you tested the output from the generator? what was the reason you have changed the regulator/ rectifier
zman
#11 PostAuthor: zman » Tue Aug 14, 2012 5:43 pm
yep gen is good.low volts across bat.was lent new reg/rec to test and all was good again.
this one does not have a brown but a black
#12 PostAuthor: z1bman » Tue Aug 14, 2012 6:10 pm
according to the H**** wiring diagram the black wire is the switched live ie goes to the brown wire on you bike. the thing that is confusing me is you have (two)red/white wires going to the permanent live do you know the exact model the replacement H**** unit is from
PAULJAC47
#13 PostAuthor: PAULJAC47 » Tue Aug 14, 2012 7:25 pm
Might seem an obvious question but this is a proved working unit i take it?
zman
#14 PostAuthor: zman » Wed Aug 15, 2012 11:49 am
REG/REC came from VF500 not a CX500 as seller said.Found diagram and all is now working.
tanks for all replys
#15 PostAuthor: ADRIAN H » Wed Aug 15, 2012 1:13 pm
Result. . . :D
