linkages
sme
linkages
#1 PostAuthor: sme » Mon Aug 13, 2012 3:54 pm
can anyone confirm this is the gpz1100 rear shock linkages?
where can i get a replacement with nuts and bolts?
as there is too much play in them
#2 PostAuthor: z1bman » Mon Aug 13, 2012 3:58 pm
you should still be able to buy the parts from a Kawasaki dealer needle roller bearings are pressed into the linkage with seals at each side
sme
#3 PostAuthor: sme » Mon Aug 13, 2012 4:43 pm
any idea of costs?
and what size should the bolts that pass through be?
#4 PostAuthor: Ginger Bear » Mon Aug 13, 2012 5:06 pm
Now THIS is a knackered one!
I replaced all the bearings & seals. Supplied by www.simplybearings.co.uk
sme
#5 PostAuthor: sme » Mon Aug 13, 2012 5:46 pm
what type of bearing unit is best used, as have looked on that website
#6 PostAuthor: Ginger Bear » Tue Aug 14, 2012 5:59 am
I found you can buy bearings with seals already fitted to one or both ends, or you can buy the seals separately, as originally fitted by Kawasaki. Either option will work.
jimmock
#7 PostAuthor: jimmock » Tue Aug 14, 2012 7:04 am
Ginger Bear wrote:Now THIS is a knackered one!
GB,
What sort of maintenance regime do you operate????
Jimmock. :wnkr
I hate people I don't like !
