discolour to down pipes
put a new 4-1 exhaust on about 2 months ago and nos 2&4 downpipes discolour at the top as normal but nos 1&3 are staying chrome,have had a few probs with blocked jets and rough running which are sorted out now ,but exhaust downpipes are still the same, why would this be , is there a underlying problem i am not aware of. all 4 pipes are hot and all cylinders are firing. any advice appreciated.
Mark O C
When a chrome pipe is new you can prevent discolouring by spring the inside of the pipe black, your pipe discoloured on 2 pipes when it was new but as 2 cylinders may have been running rich these would have sooted up and not discouloured, it could be the bike is running fine now but the sooted up pipes act as painted black pipes to prevent the discolouring , Steve
(Edited by debben1 at 4:32 pm on May 15, 2006)
- rickman CRR
i thought it might still be incorrect mixture , as get slight popping when bike warmed up and de-accelerating. (also have dyno electronic ing) have cleaned discolour off 2&3 and it returns just to those two,so think i will take it somewhere to tune it correctly , handy tip about spraying pipes though ...thanx
Hello Steve R, Yes, we used to spray the inside of customers Vance and Hines before fitting them so as to prevent the discolouring, well it works for a while, depends on how the customer rides, those that where steady riders with a priority on looks would stay looking new, others that lets say ride enthusiasticly (read thrashed/ragged/raced/cained) will still end up with discolouring unless the bike is set up on the rich side, Mine have a luvly shade of purple into blue and then gold :)
