How easy is it to remove the rubbers from the front footrest and any tips to make the job easier ?
Also, was the peg that the rubber fits on to zinc plated originally ?
front footrest rubber removal.
Agree with Ruffle, I would add, ensure they are washed well as acid during plating sometimes ingresses under the rubber and works its way out at a later date! ...I'm sure Micky would take care of this.
RegardZ.
RegardZ.
- big green bus
i had some bit zinc plated a while ago, i left the rubber on without thinking, brake lines, gear linkage etc. when they can back they looked like new even the writing on the brake hole was visable again. I asked the guy and he said they do it all the time as the process doe not effect the rubber at all.
