Z1000 Gasket Set ?
zedrob
Z1000 Gasket Set ?
#1 PostAuthor: zedrob » Thu Aug 30, 2012 4:08 pm
Does anyone have a list of what O'Rings are included with the Z power gasket sets ?
If not, does anyone know of any particular O'Rings that are not included in the set ?
The reason I'm asking is that while I was stripping the engine down, I may have binned some O'rings on the assumption that they would all be included in the gasket set :oops:
When I spoke to Zpower they couldn't tell me what was included and what wasn't.
Rust Never Sleeps !!!
Garn 1
#2 PostAuthor: Garn 1 » Thu Aug 30, 2012 5:27 pm
Zedrob, I'm pretty sure the gasket set (like most) does not include ...
Two (same size) o-rings for pressure sensor alloy casting .. very important****
Oil filler bolt o-ring
Sump plug & filter cover bolt.
Important two small shaped o-rings, one between cases & another on oil pump.
Not sure on two tacho seals (I think the o-ring but not the seal?).
Not sure about both inner large o-ring for sump and the large o-ring for filter cover.
RegardZ.
zedrob
#3 PostAuthor: zedrob » Fri Aug 31, 2012 11:20 am
Garn,
Thanks mate, very much appreciated.
Thankfully I kept all of the ones you mentioned, so maybe not as bad as I first thought :)
Hope you guy's are getting some good bike weather down there.
Summer has been a washout in Scotland
Take it easy mate
Mark Stratton
#4 PostAuthor: Mark Stratton » Fri Aug 31, 2012 12:23 pm
Zedrob
try to get one of these from Z Power as this will show all the "o" rings that you require. At least then you can see what comes with the gasket set and what doesn't.
https://www.z-power.co.uk/merchantmanag ... ucts_id=56
zedrob
#5 PostAuthor: zedrob » Fri Aug 31, 2012 1:34 pm
Cheers Mark,
I didn't know this existed, have just ordered from Zpower.
I had downloaded and printed the breakdowns from the Kawasaki website, but to be honest the diagrams weren't that clear and I was struggling to make out the detail, so this book is just what I need.
All the best.
Rob....
steve bowdler
#6 PostAuthor: steve bowdler » Fri Aug 31, 2012 1:42 pm
zedrob
#7 PostAuthor: zedrob » Fri Aug 31, 2012 7:41 pm
Cheers Steve,
Being a true Scot, I like free things, now saved in my favs
Another small result today was getting Dave Marsden's book on Amazon, I hadn't realised it was reprinted, jeez, I nearly paid a small fortune for a second hand one on ebay last year :)
Regs,
Rob....
Users browsing this forum: A4Ade and 27 guests
