how do I fit an oil cooler help please
woody1968
#1 PostAuthor: woody1968 » Thu Sep 27, 2012 2:17 pm
Dear all, any help advise and piping diagrams for how to fit an oil cooler to my Z900 please.
I have picked up myself a hyabusa oil cooler rad and want to find out how I fit it, I have just rebuild my engine using some original Acorn Four race pistons and I think that it may need the oil cooler so am going for this.
any help would be greatly appreciated.
email if you like @ woody1968@gmail.com
thanks
John
#2 PostAuthor: Pigford » Thu Sep 27, 2012 3:51 pm
Usually, the oil pressure switch unit (located behind the barrels, under the cam chain adjuster) is replaced with a 2 x take off which is then connected to the oil cooler :wink:
#3 PostAuthor: chrisu » Thu Sep 27, 2012 7:04 pm
just done this on my Z1 so pm me and i'll run you through the process and what to buy.
Zed1015 and GB were a lot of help !!!
http://z1ownersclub.co.uk/forum/viewtopic.php?t=20819&highlight=cooler
sanderz
#4 PostAuthor: sanderz » Thu Sep 27, 2012 7:11 pm
Pigford wrote:Usually, the oil pressure switch unit (located behind the barrels, under the cam chain adjuster) is replaced with a 2 x take off which is then connected to the oil cooler :wink:
http://www.debben.co.uk/acatalog/Z900.html
You would then require the hoses & fittings to suit - Debbens could provide these or you could try -
http://stores.ebay.co.uk/Torques-U-K?_t ... 4340.l2563
Wots up DOHC
#5 PostAuthor: chrisu » Thu Sep 27, 2012 7:17 pm
you can route the pipes in a number of ways..................
#6 PostAuthor: Ginger Bear » Fri Sep 28, 2012 6:52 am
There has been various discussion on which way up to mount your cooler. If you mount it with the fittings on top, there will be a lot less oil to 'drain back', making it kinder to the engine on start up.
#7 PostAuthor: Pigford » Fri Sep 28, 2012 8:58 am
Wot bear syas - plus your overall engine oil capacity is increased a bit :wink:
woody1968
oil cooler help
#8 PostAuthor: woody1968 » Fri Sep 28, 2012 1:00 pm
thanks to all so far this is proving very helpful
john
