Chemical Blacking or Zinc plating black passivate
GPRD
#1 PostAuthor: GPRD » Mon Oct 01, 2012 7:33 pm
Can anyone recommend the best way to go. I'm wanting to 're-black' all the nuts and bolts on the GPZ750R1 project, and I was going to chemical black them, but I was told today that that will give little or no corrosion protection, and that I should find someone to zinc plate them with black passivate.
Anyone got any experience they would like to pass on on this issue?
What we got here, is failure to comunicate.
kas750
#2 PostAuthor: kas750 » Mon Oct 01, 2012 7:43 pm
I used black passivate zinc on my kh400 special.All the rearsets,kickstart and nuts and bolts were done that way.I used it mostly because it looked good and was cheap!...It has lasted pretty well and has only faded a little over the past couple of years.
z1000puddin
#3 PostAuthor: z1000puddin » Mon Oct 01, 2012 7:49 pm
Black chromate is now banned I think you will find,due to being carcinogenic (I think that is the correct spelling) this would have given a good corrosion protection.
Black passivate,on the other hand does not give the corrosion protection ( I think it ranges between 70 hours - 240 hrs.
I may be wrong here but the possible way to go would be to have the parts zinc plated, then black passivate.
Mikey may be the one to answer this
Try these guys out
http://www.metalcolours.co.uk/zinc-nickel-plating.php
Stu
Zed til Dead
GPRD
#4 PostAuthor: GPRD » Mon Oct 01, 2012 8:14 pm
z1000puddin wrote:Black chromate is now banned I think you will find,due to being carcinogenic (I think that is the correct spelling) this would have given a good corrosion protection.
Try these guys out
Stu
Sorry, I meant get them zinc plated first, then black passivated.
Do those people do small private jobs?
Yes, I read that stuff was banned, I hadn't heard of it anyway!
GPRD
#5 PostAuthor: GPRD » Mon Oct 01, 2012 8:15 pm
kas750 wrote:I used black passivate zinc on my kh400 special.All the rearsets,kickstart and nuts and bolts were done that way.I used it mostly because it looked good and was cheap!...It has lasted pretty well and has only faded a little over the past couple of years.
I must say, I do like your bike.
I looks like Zinc plating with black passivate is the way to go.
z1000puddin
#6 PostAuthor: z1000puddin » Mon Oct 01, 2012 8:19 pm
Kas,
That is a very nice KH.
WHAT ARE THE PIPES ??
Stu
Zed til Dead
kas750
#7 PostAuthor: kas750 » Tue Oct 02, 2012 6:01 am
They are one off's with tapered headers to suit my porting job and kr1s carbs. :D
The Zedster
#8 PostAuthor: The Zedster » Tue Oct 02, 2012 6:13 am
I have done all the bolts on my gpz 550 using a zinc plating kit and black passivate , take a look at my pictures
http://s924.photobucket.com/albums/ad90 ... storation/
GPRD
#9 PostAuthor: GPRD » Tue Oct 02, 2012 6:57 am
The Zedster wrote:I have done all the bolts on my gpz 550 using a zinc plating kit and black passivate , take a look at my pictures
Well thats convinced me!
You must of spent plenty of time blasting, its not a quick job, (unless you have a top compressor).
Can you tell me, do you have to passivate it immediately after plating? What I'm getting at is, if I sent my stuff to a local plater (they don't do black passivate due to water condition) could I black passivate it a day or two after?
rodge70
#10 PostAuthor: rodge70 » Tue Oct 02, 2012 7:29 am
my brother(mikey) did this lot for me,think he gives it a quick polish first for a better finish.
The Zedster
#11 PostAuthor: The Zedster » Tue Oct 02, 2012 4:05 pm
I am sure you have to passivate right after plating before it starts to oxidise,
Yes It takes alot of time to do, first clean and degrease each part, then blast them to take off rust and old plating, degrease, acid pickle then plate , followed by passivate,
GPRD
#12 PostAuthor: GPRD » Tue Oct 02, 2012 7:05 pm
I've spoken to some platers and yes, I have to passivate straight after plating, so, looks like a lot of work for me!
Thanks for all the input.
RAYZ1
#13 PostAuthor: RAYZ1 » Wed Oct 03, 2012 9:18 pm
very impressive work!!
