footrest rubbers
A1John
footrest rubbers
#1 PostAuthor: A1John » Thu Oct 04, 2012 7:45 am
are the rear footrests rubbers on a z1b the same as a z1-z1a ? ta
pertonpc
#2 PostAuthor: pertonpc » Thu Oct 04, 2012 8:04 am
Hi John,
Rear footrest rubbers on Z1 and Z1A have a hole in the end with chrome showing through.
Z900A4 has solid rubber footrests.
The Z1B fell between the two - early ones were using up the ones with the hole in from factory stocks and by the end of the run they were using the later ones.
In other words both types could have been fitted depending on early or late frame number.
Both types are still available new so you can choose.
From Mark
