Fuel tap refurb
tlc
Fuel tap refurb
#1 PostAuthor: tlc » Mon Oct 08, 2012 7:34 pm
I dug out an old fuel tap for a member that needed a part.
After discussions it seems that mine is salvageable and is worth trying to restore.
In really good shape overall I only need new gauzes for the pipes but after a fruitless search of the forum I`m asking if anyone can help.
I was sure someone had restored one from a Z1.
wilsonsjw11
#2 PostAuthor: wilsonsjw11 » Tue Oct 09, 2012 5:35 am
Chris
I believe the small gauze filters are avialable as a lawn mower part,maybe Atco.The other problematic part is the internal cup shaped rubber,they go hard, and this used to be available from Americanclassix.
I think Chris Smith restored his original fuel tap as I did during the 73 Z1 rebuilds.The internal rubber being soaked in petrol or thinners overnight and greased with brake caliper silicon before assembly.
Regards
Steve
rodge70
#3 PostAuthor: rodge70 » Tue Oct 09, 2012 7:14 am
i used the filter from a gxhonda tank
the rubber fuel pipe helps to hold it in the tap hole
