z650 rear drum wheel
ash
#1 PostAuthor: ash » Sat Oct 13, 2012 7:16 am
Now this is a maybe but putting this on just incase someone has one
18 inch
Taffus
#2 PostAuthor: Taffus » Sat Oct 13, 2012 7:56 am
alloy or spoked?
ash
#3 PostAuthor: ash » Sat Oct 13, 2012 8:02 am
Mark alloy mate, not 100% yet but its a maybe, gonna check in a bit think mines got a slight buckle,
ash
#4 PostAuthor: ash » Sun Oct 14, 2012 2:08 pm
Mark had a good check of the back wheel and it aint buckled which im happy about, thanks for your feedback mate :D
Did you say you had spoked wheels also,
Taffus
#5 PostAuthor: Taffus » Sun Oct 14, 2012 3:41 pm
set of kawasaki alloys and a set of cma's
ash
#6 PostAuthor: ash » Sun Oct 14, 2012 3:47 pm
Mark the cma,s are alloys aint they
Taffus
#7 PostAuthor: Taffus » Sun Oct 14, 2012 4:13 pm
Yes, paid a lot for then too! :shock:
ash
#8 PostAuthor: ash » Sun Oct 14, 2012 4:30 pm
Ok mate, wouldnt mind some spokes but goto see how things go, did you see my carb thread
gray
#9 PostAuthor: gray » Sun Oct 14, 2012 8:23 pm
Just looked in the garage , I've a rear drum /spoked wheel that i think's off a 650. got it in a job lot with a z650B3 project which is now gone
18" diam, 2.15x18 rimsize stamped on the rim
17mm diam axle
"usable range" casting on the brake backplate
42 teeth on the sprocket. 6 bolt sprocket carrier.
drum diam looks like 178mm.
will need respoked (rusty) and new rim ( hefty tyre lever marks or something) and blasted/polished.
complete with axle, nut and spacers,
and chain adjusters possibly if i can find them
gray
gray
#10 PostAuthor: gray » Sun Oct 14, 2012 8:24 pm
17mm diam axle
gray
malc87
#11 PostAuthor: malc87 » Sun Oct 14, 2012 10:28 pm
Got this?
