z1100 carbs vs gpz750 carbs
pluto
#1 PostAuthor: pluto » Sun Oct 14, 2012 4:16 pm
Does anyone know if gpz750r1 cv carbs can successfully be dynojetted to be used on my gpz1100? I have recently bought a set of 750 carbs which when compared to the z1100 carbs are very different. They are both 34mm mikuni cv's. I dont want to spend £100 on the dynojet kit to find they are totally unsuitable.
Dave
1100 carbs at top
750 carbs
1100 carbs
steve.w
#2 PostAuthor: steve.w » Sun Oct 14, 2012 5:59 pm
the only diff is the carb tops and overflow system i just sold a set of 750 34mm s what were fitted to a 1100 dyno-jetted stage 3 :wink:
pluto
#3 PostAuthor: pluto » Sun Oct 14, 2012 6:19 pm
Cheers Steve,
Do the tops need changing? Is it the overflow system that connects between the 2 outer carbs? Could you put me in touch with the new owner so I could get some jet sizes / needle numbers ?
Dave
steve.w
#4 PostAuthor: steve.w » Sun Oct 14, 2012 6:38 pm
[quote="pluto"]Cheers Steve,
Dave[/quote no mate the only diff is one is metal the other plastic yep thats the over flow system just buy a stage 3 for an 1100 and ull be fine :wink:
