Does the z1r use the same throttle tube as Z1000 a1/2
Hi, need a throttle tube for my 78 z1r , but is a Z1000 a1 a2 the same, i know they are different part numbers but not sure if thats because of the grip that comes with it, any ideas ? Ross
# 364
78 z1r
78 z1r monoshocked
78 z1000 a2
83 z1000r elr
83 z1000r elr monoshocked
78 z1r
78 z1r monoshocked
78 z1000 a2
83 z1000r elr
Ross, If we are referring to the same item.... "Throttle Tube"~ the tube that fits on the handle bars you turn to open the throttle, then, I think they are all inter-changeble and are just made to fit the 7/8" (or whatever) handle bars.
The Z1R and A1 & A2 fit inside the accompanying control-switches.
Some may have non-standard quick action mechanism on them!
RegardZ
RegardZ
Yes, talking about the same item. Z1r and z1000 use different throttle cables as well, according to parts books. Seems odd. I have been using quick action throttle as well, fancy going back to original type. And need a tube.
# 364
78 z1r
78 z1r monoshocked
78 z1000 a2
83 z1000r elr
78 z1r
78 z1r monoshocked
78 z1000 a2
83 z1000r elr
