Running rough
mikey
Running rough
#1 PostAuthor: mikey » Sun Nov 04, 2012 7:52 am
Not used my ltd for a while last time was about 3 weeks ago,
so thought id take it for a run yesterday,
was a real bitch to start and when i got it running it was running rough
but running on all 4, and when i revved it up the revs would linger up
for a while then drop back to a tick over.
And even with the engine warm it would only start with the choke on.
Any thoughts guys.
#2 PostAuthor: ZedHead » Sun Nov 04, 2012 10:29 am
could be fuel has gone off in the float chambers
z1000puddin
#3 PostAuthor: z1000puddin » Sun Nov 04, 2012 10:36 am
Definitely sounds like a fuel/ carb issue mikey
stu
Zed til Dead
#4 PostAuthor: Al » Sun Nov 04, 2012 11:28 am
Tiny bit of water in the fuel,( now in float bowls) or leaks at the carb to head rubber. Did you glue the intake rubbers on? Tighten the jubilees' a little and if it gets worse they may have splits in.
KeithZ1R
#5 PostAuthor: KeithZ1R » Sun Nov 04, 2012 11:47 am
Check your closing cable has very little free play and it pulln the slides shut completely
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
mikey
#6 PostAuthor: mikey » Sun Nov 04, 2012 12:28 pm
Cheers guys this is what i was thinking carb/fuel prob
carbs off i guess
:cry:
No closing cable on this one keith ltd type motor.
KeithZ1R
#7 PostAuthor: KeithZ1R » Sun Nov 04, 2012 12:34 pm
There you go somfin else learned ☺
Keith
:bop :gom
mistaken.
Users browsing this forum: doebag and 61 guests
