Euro spec switch LHS internals
DogsbolloxofZ1B
#1 PostAuthor: DogsbolloxofZ1B » Sun Nov 04, 2012 9:14 pm
Help! Does anyone have a uk Z1 or Z1A who could take a few internal shots of the left hand switch :?:
I'm rebuilding a switch which goes from low beam to Pass and it doesn't spring back to low beam as it should. I can't see what's missing in the upper half. I'm sure there was a spring or a piece of sprung steel that returned the switch knob from pass back to low beam. :evil:
Mike
DogsbolloxofZ1B
#2 PostAuthor: DogsbolloxofZ1B » Sun Nov 04, 2012 9:59 pm
Just located a few images prior to restoring, think I've solved it but would be good to other switches. Looks like a small 5mm wide bit of spring steel is all it is and mines broken shxte I'll have to fabricate one.
DogsbolloxofZ1B
Spring Steel: Profiling/forming shapes
#3 PostAuthor: DogsbolloxofZ1B » Sun Nov 04, 2012 11:34 pm
Where can I buy a sheet of Blue spring steel from? approx 0.012" thick x 0.25" wide or similar.
How do you profile spring steel? I seem to recall you heat till it glows Red, form the profile you need, probably a few attempts, quench in oil and jobs a goodun :lol: I'm sure its not that easy but if anyones made something similar let me know how you got on.
Mike
Zed man
#4 PostAuthor: Zed man » Mon Nov 05, 2012 12:51 am
DogsbolloxofZ1B wrote:Just located a few images prior to restoring, think I've solved it but would be good to other switches. Looks like a small 5mm wide bit of spring steel is all it is and mines broken shxte I'll have to fabricate one.
Looking at the spring, you could make one from a clock spring, go to a Charity shop or car boot, and get one of those old fire place clocks, ( with a wind up key type) and get the spring out and make your spring.like this one. http://www.ebay.co.uk/itm/Wind-up-tavel ... 2577376c80
http://www.ebay.co.uk/itm/Vintage-Retro ... 5aeb1ab9bc
Z903
#5 PostAuthor: Z903 » Mon Nov 05, 2012 7:52 am
Maybe an old points spring?
DogsbolloxofZ1B
#6 PostAuthor: DogsbolloxofZ1B » Mon Nov 05, 2012 12:37 pm
Thanks both great ideas.
Mike
Z903
#7 PostAuthor: Z903 » Mon Nov 05, 2012 8:10 pm
Be great if you can keep some pictures of how you do this.
I have a US version of this switch (where the Pa is blanked off) which I need to get going properly.
I assume there must be a loop wire to this contact as well?
