z1r parts
ross
z1r parts
#1 PostAuthor: ross » Sun Nov 04, 2012 9:30 pm
hi, can anyone help with some parts please for a z1r. as i am near to getting the kosman kit welded on and the frame painted, so
i need......
a throttle tube, the bit cables connect to.believe same as gpz550 d1
a hazard lights relay and an indicator relay and a strap
a sidestand
an alternator blue plug with a small amount of wires with it
seat base, or a tatty seat as will only be using the base.
front footrests, or a drawing /template of how they bolt onto the frame as i want to make brackets to match my bandit rear footrests, but in std z1r position.
know i am asking a lot but i have been watching ebay for quite a while now and no joy on these bits, will obviously pay . thanks ross
# 364
78 z1r
78 z1r monoshocked
78 z1000 a2
83 z1000r elr
83 z1000r elr monoshocked
KeithZ1R
#2 PostAuthor: KeithZ1R » Sun Nov 04, 2012 9:46 pm
Ross dont understand what throttle tube ?
Indicator relay readilly availablefrom VWP
Hazard relay any modern timed relay will do that with a few mods
Side stand cant help
May have the plug will look
Think ive got a tatty base
Pretty obvious were the footrests bolt theres two threaded holes at the bottom of the frame V section in a 45 degree line below the front of the side panels engine rear these take two studs the footrests bolt to them
Pm me on hols at present
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
