Remove Rotor
Z1B Alan
Remove Rotor
#1 PostAuthor: Z1B Alan » Tue Nov 06, 2012 9:14 pm
Would anybody be able to tell me the size (Diameter and Pitch) of the bolt I require to remove the rotor on my Z1B as I have to investigate a noisey starter clutch. :oops: Also has anybody heard of placing a ball bearing on to the end of the crank ahead of the bolt in order to ease breaking the taper :?: . Just to prove that I am stupid :oops: :oops: is it a right or left hand thread.
hillbilly
#2 PostAuthor: hillbilly » Tue Nov 06, 2012 9:25 pm
i thought the front wheel axle thread will undo it,as same thread.
could be wrong.
#3 PostAuthor: z1bman » Tue Nov 06, 2012 9:35 pm
centre chrome steering stem nut
z1000puddin
#4 PostAuthor: z1000puddin » Tue Nov 06, 2012 9:35 pm
Alan,
Pretty sure it is M16 same as swing arm spindle & front axle.
It is right hand thread.
I have heard that the ball bearing does help.
Stu
Zed til Dead
