The sun is out lets ride
Padders
#1 PostAuthor: Padders » Sun Nov 11, 2012 10:48 am
At last the bloody sun has turned up on the weekend. Just waiting for Ted and Steve to turn up then we are off for a spin to turn the oil in the bikes. Will post a couple of pictures later.
PUM 13
Rhencullen
#2 PostAuthor: Rhencullen » Sun Nov 11, 2012 5:38 pm
I actually got the GT380 out today - and ended up pushing it home :roll: Had major electrical problems, with things beginning to 'shut down' and the bike started missing a lot. Switched the lights off, and things improved for a while as I limped homewards. Then the indicators stopped working, and the dimly glowing neutral light extinguished itself about a mile from home.
Closer inspection and removal of the battery revealed no electrolyte in the cells, which might not have been helping things :oops: Now on charge - fingers crossed - and further investigations pending.
ted1r
post
#3 PostAuthor: ted1r » Sun Nov 11, 2012 6:43 pm
Nice ride out Ian .Lovely day dont seem like November.
Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
#4 PostAuthor: Pigford » Sun Nov 11, 2012 6:56 pm
Come on - it's dark now - so where's the photo's :roll:
I took me W650 for a spin after fitting a "jet-kit" to sort out the lean running these modern bikes suffer...... new plugs & checked the valve clearances and she's sweet as - well chuffed :twisted:
jimmock
#5 PostAuthor: jimmock » Sun Nov 11, 2012 9:22 pm
Rhencullen wrote:I actually got the GT380 out today - and ended up pushing it home :roll: Had major electrical problems, with things beginning to 'shut down' and the bike started missing a lot. Switched the lights off, and things improved for a while as I limped homewards. Then the indicators stopped working, and the dimly glowing neutral light extinguished itself about a mile from home.
I AM SHOCKED!!!
What happened to your pre ride checks??????
Jimmock. :wnkr
I hate people I don't like !
Rhencullen
#6 PostAuthor: Rhencullen » Sun Nov 11, 2012 10:31 pm
jimmock wrote:I AM SHOCKED!!!
You're right of course..... but to be fair, when the battery is in-situ, the sides aren't visible to check the electrolyte level - and with it being kick-start only, I didn't realise there was a problem until too late :(
I'll be taking the battery out and checking it more regularly from now on though ( assuming it's not knackered ).
