When is an o-ring not an o-ring ?
td5_pete
#1 PostAuthor: td5_pete » Thu Nov 15, 2012 10:46 pm
I just removed the oil cooler, and crankcase feeds from my z1000 A1 as I want to return to the standard oil pressure switch housing.
Is there anything special about the o-rings that seal it to the case ?
I couldn't work out if they had a flat profile because they've been compressed for 30 years, or if they're meant to look like that. :D
Will any new o-ring of the right size do ?
I was going to buy a 440 piece o-ring kit so I'd always have a stock in the workshop, but I see I can pay from £6 on eBay to £50 for o-rings made from 'viton' .
As far as I can make out cheap = made from 'nitrile' and good to 120c.
Expensive = made from 'viton' and good to 200c.
What are you supposed to use in bike engines ? Can't seem to find the answer anywhere else. :roll:
Thanks for reading.
kz1000 custom cafe racer, GPz750 unitrack x2, XJR1200
Paid up club member.
#2 PostAuthor: z1bman » Thu Nov 15, 2012 11:40 pm
part no 670B2018 still available from kawasaki
#3 PostAuthor: Ginger Bear » Fri Nov 16, 2012 7:44 am
Pete, new ones will have a round profile, as you suggest 30 years + will have left them a little flat.....
jimmock
#4 PostAuthor: jimmock » Fri Nov 16, 2012 10:02 am
Surely you wont need 440 O rings to fix the problem??
Jimmock. :wnkr
I hate people I don't like !
steve bowdler
#5 PostAuthor: steve bowdler » Fri Nov 16, 2012 11:45 am
jimmock wrote:Surely you wont need 440 O rings to fix the problem??
When I saw Jimmock had responded to this question I was afraid to open up the subject especially in work :lol:
jimmock
#6 PostAuthor: jimmock » Fri Nov 16, 2012 12:17 pm
Wise move Steve,
Guys have been sacked for less!!!
As you know, I search the site constantly for engineering problems that I can offer engineering solutions to.
Jimmock. :wnkr
StevieT
#7 PostAuthor: StevieT » Fri Nov 16, 2012 8:11 pm
Viton is a flurocarbon rubber and probably 'over engineered' for any standard road going air cooled Z. It's used where maximum resistance to elevated temperatures are required. However it has a low compression set so won't exhibit the problem you describe.
I doubt Kawasaki were using them in the 70's or early 80's though!
Z1A
td5_pete
#8 PostAuthor: td5_pete » Fri Nov 16, 2012 10:07 pm
StevieT wrote:Viton is a flurocarbon rubber and probably 'over engineered' for any standard road going air cooled Z. It's used where maximum resistance to elevated temperatures are required. However it has a low compression set so won't exhibit the problem you describe.
Cheers for that ! - makes a lot of sense. Always happy to save some money
:lol:
DogsbolloxofZ1B
#9 PostAuthor: DogsbolloxofZ1B » Sat Nov 17, 2012 7:22 pm
Viton range of 'O' rings, for the most part, are dimensionally the same as OEM whereas rubber ones aren't. You can normally find a rubber "O" ring in a kit with same OD but its CS is not the same normally smaller in Cross sectional diameter.
My two cents, take a look at: http://www.polymax.co.uk/o-rings/rubber ... s284-viton
Mike
KeithZ1R
#10 PostAuthor: KeithZ1R » Sun Nov 18, 2012 1:09 am
Good info but do they work the same ?
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
