Hi guys
I've just refitted the wiring loom to my resto gpz750 twin shock
I put battery back in and got power
I think the battery is goosed
Anyway with the lights off the brake sensors front and back are working the rear light
When I switch the lights on the brake light is not coming on
The bulbs are ok
Is it just poor power from battery the starter relay is just clicking
Ta
Brake light
Make sure you have a good 13.2 volts off load,if you mean the starter is clicking and not turning the motor over suspect battery is us,or you may have a bad earth,put a pair of jump leads off a known good battery on in parallel.
..Paul J
..Paul J
