i have this set up?
the master cylinder is "NOT" stamped 5/8??
i dont recognise this bracket either(one on each side) as its different from the one on the bike?
Garn 1 wrote:Mal, Those brackets are certainly not the Z1 series brackets, although that splitter block is one of that era. The brackets should look like this..
http://cgi.ebay.com.au/kawasaki-Z1-900- ... dZViewItem
As Davy D says they could be off the H1 H2.
With regards to the master cylinder, I have heard of some 5/8 " not being so designated with a stamping on the bottom in which case you will have to measure them as Rick'CRR suggests. Not easy to visually check as I think they use the same circlip at the piston entry side.
RegardZ
Davy Doherty wrote:No they aren't, so i'll have them, i will pay postage for you of course,
