Z1 carb overflow pipe
DaveZ1
#1 PostAuthor: DaveZ1 » Mon Nov 26, 2012 8:25 pm
Need to source some new overflow hoses for my Z1. Anyone know what the correct Bore and OD size of these hoses are?
Cheers Dave
Garn 1
#2 PostAuthor: Garn 1 » Mon Nov 26, 2012 8:47 pm
Dave, can't tell you the size or the source of those tubes. I will offer some advice though... Use the smaller diameter size and don't under-estimate the length overall, required to have all four ending up at the same drain point.
Auto shops sell the old vacuum type black rubber tubing used for vacuum wipers etc. This will usually get you out of trouble.
Regardz.
#3 PostAuthor: z1bman » Mon Nov 26, 2012 9:04 pm
