Z1100A1 J1 J2 R1 CLOCK/SPEEDO TACHO BRACKET 25008-1034
Hi I am looking to buy the speedo tacho mounting bracket for a Z1100A1 KZ1100A1 shaft drive 1981 if anyone has one for sale.
As below it i the same part as the J model and R1
PUM 13
- london calling
- Ginger Bear
Ian, part No. is 25008-1034 & according to Kawasaki.com is common to these other models;
Model (5):
KZ1000-J1 (1981)
KZ1000-J2 (1982)
KZ1000-R1 (Eddie Lawson Replica) (1982)
KZ1100-A1 (Shaft) (1981)
KZ1100-A2 (Shaft) (1982)
I do have a set of 'J' clocks, but from memory they are fractured around the mounts. I will go & check once I can get away from all the family festivities...
Model (5):
KZ1000-J1 (1981)
KZ1000-J2 (1982)
- london calling
- Ginger Bear
steve.w wrote:http://www.ebay.co.uk/itm/Kawasaki-Z-1000-J1-Speedometer-Tachometer-Clocks-Bracket-/330825424987?pt=UK_Motorcycle_Parts&hash=item4d06bb605b
This one is broken, the mounts to the top yoke have snapped off. Pity the seller didn't care to mention it in his description. There are pictures, but if you didn't know what you were looking for........
- paul doran
J brackets
These are hard to find meanwhile.
Most they are broken!
I found one some years ago made of stainless steel - little bit to thick but unbreakable. So far I know a small series was made.
If this is not for a showroom-condition-bike with only genuine parts I think stainless stell is the very best solution.
PS: I gave mine to a friend who use it until today
KERKER kicks ass!
- Ginger Bear
Just found a steel replacement on Alan's Kipkawa site;
http://www.kipkawa.co.uk/parts.php?link=NEW%20PARTS
