REAR DISC QUERY
dave cullen
REAR DISC QUERY
#1 PostAuthor: dave cullen » Wed Jan 09, 2013 1:02 pm
hi,
my Z1000A1 rear wheel is quite hard to turn when bike on stand for chain oiling/cleaning etc; it wheels about easily enough, and does not heat up when running at all, so im pretty sure the pads arent binding; its always been like this, and as none of my other disc braked bikes have a centre stand for easy comparison, i just cant figure out if its meant to spin freely like a drum brake, or if its just the way it is with models such as the Z1000/Z1R etc?
appreciate any views
thanks
Taffus
#2 PostAuthor: Taffus » Wed Jan 09, 2013 3:53 pm
could be a bearing on the way out or over tightened wheel or missing spacer, it should run easily
Mark Tiller
#3 PostAuthor: Mark Tiller » Wed Jan 09, 2013 4:56 pm
Lever the pads away from the disc and try wheeling it again, it should move freely if not....as said b4 bearings/missing spacers/ or chain?
07962421462
