exhaust collets
daveltd
exhaust collets
#1 PostAuthor: daveltd » Wed Jan 09, 2013 8:33 pm
Can somebody tell me the dimensions of z1000a and z1000j collets as i have a set to sell but not sure what model they fit cheers Dave
dmltd
Garn 1
#2 PostAuthor: Garn 1 » Sat Jan 12, 2013 12:10 pm
So you are really just after the Outside diameter of a z1000A exhaust pipe at the manifold and compare it with J motor exhaust pipe.
Now as i understand it, the Z1000A2 has the same Od as a Z900. So,I will be able to give you this tomorrow..... Someone else with a J motor can give you the OD of the J.
My guess, the J will be slightly bigger! But, maybe the same!
RegardZ.
#3 PostAuthor: z1bman » Sat Jan 12, 2013 12:37 pm
these are the collets fitted to the j + gpz models
http://www.ebay.co.uk/itm/New-Genuine-K ... 0943477581
these are for the z1/ z1000a models
http://www.ebay.co.uk/itm/Kawasaki-NOS- ... 0256729590
Mr Puffin
#4 PostAuthor: Mr Puffin » Sat Jan 12, 2013 6:16 pm
They different lengths. The J type are shorter, to fit the Kerker pipe`s to my J and septic i had to use the longer early 900 1000 type of collets. The Kerker was meant for an A1 the other an A4 :wink:
Garn 1
#5 PostAuthor: Garn 1 » Sat Jan 12, 2013 8:48 pm
Taking notice of both Z1bman & Mr Puffin posts, the length of the earlier Z1, Z900 & z1000 is 28mm overall.
Hopes this gives a definitive decision. I guess the later Z1000J will be smaller.
RegardZ.
