Steering Damper Parts - Steering Damper Parts
Jumbo
#1 PostAuthor: Jumbo » Mon Jun 05, 2006 5:27 pm
I am looking to replace the two rubber inserts on the ends of a steering damper. They are only round rubber with a steel insert tube. I am unsure of the manufacturer of the steering damper. Anyone know of a supplier.
Cheers Jumbo
london calling
#2 PostAuthor: london calling » Mon Jun 05, 2006 7:50 pm
Hi Jumbo if it is a Kawasaki type steering damper,7 way adjustable i'm pretty sure they are un-servicable but i'm not 100% sure.The White Power,Ohlins,etc are re-buildable.
If you speak to Dave or Phil at Z-POWER,tel 01942 262864 they should be able to tell you if it's possible to repair your damper.
Garn 1
#3 PostAuthor: Garn 1 » Tue Jun 06, 2006 1:03 am
Jumbo, I think your only chance is to press the rubbers out of the ends of a discarded/ disused second-hand unit. As Jack says, the damper tube itself is un-servicable.
RegardZ.
#4 PostAuthor: Pigford » Tue Jun 06, 2006 5:54 pm
Jumbo... I've got a patern one... the manufacturer is
NHK Precision Co. Ltd... but i don't have a number!!!
I got it from fleaBay... from a bloke called: Bardsey, postcode: SY24 5JS... if any help... I shall try to get more info for you matey!
