oil......mineral v semi synthetic
chrispyduck
#1 PostAuthor: chrispyduck » Sun Jan 13, 2013 8:47 pm
Just changed my oil :lol:
Despite only covering a few hundred miles last year i still kept to my routine annual oil change however this time i decided to use Shell Advance Mineral oil instead of the Morris Semi Synthetic :wink:
What are the limitations of mineral oil and am i likely to notice any difference :?:
Fat girls are like M****s, they are fun to ride, you just don`t want your mates to see you.
#2 PostAuthor: Ginger Bear » Sun Jan 13, 2013 9:22 pm
Chrispy,
You'll find these old Zed's are so 'over engineered' they'll probably run on old chip oil, not that I'd recommend that of course.
The underlying issue is that these bikes have a wet clutch, so a bike specific oil is advisable, since so many car oils have 'friction modifiers', which aren't designed for a wet clutch.
Just think back to what oil was available when these bikes were new? Any modern 'basic' oil will be a vast improvement & unless you're running a highly tuned motor, I'd stick with something sensible & change it & the filter every year.
...... Mmmmm, seem's I've 'gone on a bit'.............. :oops: :oops:
Tonto
#3 PostAuthor: Tonto » Mon Jan 14, 2013 10:00 am
Chrispy: I would defo go for the mineral: a few months ago I tried my A4 with semi synthetic - result was instant clutch slip.
Quick change to Castrol Evo 10-40 mineral, and she ran like a tot (well that was until my front disks warped :evil:)
#4 PostAuthor: Pigford » Mon Jan 14, 2013 4:40 pm
You could run Fully Synthetic mineral oil - if its designed for a wet clutch....
Debbens recommend this stuff: http://www.performanceoilsltd.co.uk/ams ... cycle.html
I used it in me Z1000 for a few years..... no probs... even running a few 1/4 miles at Santa Pod :wink:
saab9002
#5 PostAuthor: saab9002 » Tue Jan 15, 2013 12:35 pm
Tonto wrote:Chrispy: I would defo go for the mineral: a few months ago I tried my A4 with semi synthetic - result was instant clutch slip.
I did the same on my GPZ1100, result; two oil changes in 50miles :roll:
Chris
dave cullen
#6 PostAuthor: dave cullen » Wed Jan 16, 2013 8:54 pm
asda doing 4 litres of 10-40 or 15-40 semi synthetic for £12, they did have mineral oil as well im sure;
home bargains had 4 litres of gulf 10-40 for £10, great prices
(I use mineral oil in my Z's have done for 35 years, never had a problem, whatever is on sale in asda or tescos!)
Toyboy
#7 PostAuthor: Toyboy » Wed Jan 16, 2013 10:04 pm
Buy the best you can afford. It's still cheaper than an engine rebuild. I use mineral for breaking in new rings. Then a good semi synth without the stuff that makes clutches slip they put in car oil. Cheap oils break down quicker and leaves a nasty mess in your sump
#8 PostAuthor: Ginger Bear » Thu Jan 17, 2013 7:22 am
Toyboy wrote: Cheap oils break down quicker and leaves a nasty mess in your sump
A bit like this :?
Image :fou
andyb1962
#9 PostAuthor: andyb1962 » Thu Jan 17, 2013 7:54 am
A bit like this :?
Image :fou
If you dont do many miles and change it every year. it should not be a problem. Even " cheap" oils are modern and better than most oils of the 70's
:wink:
Andy :wink:
dave cullen
#10 PostAuthor: dave cullen » Thu Jan 17, 2013 7:59 am
my point exactly, most of our bikes (not all before the howls of protest) do little mileage, arent thrashed and get oil changed every year, so a mineral oil off the supermarket shelf is pefectly adequate
#11 PostAuthor: Ginger Bear » Thu Jan 17, 2013 9:10 am
That's what I was trying to say at the beginning of this thread.
#12 PostAuthor: Pigford » Thu Jan 17, 2013 2:27 pm
I use posh stuff as mine gets used & thrashed (sometimes) .... and oil is the LIFE BLOOD of an engine and I won't skimp :!:
That said - a cheap Mineral Oil manufactured nowadays is probably much better than a good one back then :wink:
The AMSOIL is specifically designed for ROLLER BEARING cranks and WET CLUTCHES... (H-D's :oops: ) so it's ideal.
A lot of the hi-spec synths are too slippy and can ruin ROLLER bearings as the bearings just SLIDE, rather than ROLL :??
PAYS YER MONEY - MAKES YER CHOICE :wink:
KeithZ1R
#13 PostAuthor: KeithZ1R » Thu Jan 17, 2013 3:09 pm
Which is exactly what I do every 1500 miles with GTX laterly and GTX semi Synth now and despite popular belief I suffer no clutch slip at all
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
dave cullen
#14 PostAuthor: dave cullen » Thu Jan 17, 2013 8:06 pm
so you want to get to asda then keith!!
chrispyduck
#15 PostAuthor: chrispyduck » Thu Jan 17, 2013 9:04 pm
loving the responses :D
I reckon oil from Asda is best kept for the kitchen :lol:
I will continue with semi synthetic although have Shell mineral for this year which i am sure will be fine even with a few planned laps of Mallory at festival 1000 bikes.
Was oil really that bad in the 70s.........i used to thrash around on my GS550 using Castrol GTX..... :roll:
