GPz1100 Outer Sprocket Cover
HarrisTZ
#1 PostAuthor: HarrisTZ » Mon Jan 14, 2013 9:34 am
Hi all
As per the subject, wanted outer sprocket cover for GPz1100 or the like.
It is going to be cut to fit so cheap works here :wink:
london calling
#2 PostAuthor: london calling » Mon Jan 14, 2013 9:45 am
I might have something,but it will take a few days to check.
Jack
HarrisTZ
#3 PostAuthor: HarrisTZ » Mon Jan 14, 2013 8:23 pm
Great news.
Look fwd to hearing from you
martinz1000r
#4 PostAuthor: martinz1000r » Tue Jan 15, 2013 9:10 am
If Jack doesn't have one I can help out. Do you want B model or Unitrak?
HarrisTZ
#5 PostAuthor: HarrisTZ » Wed Jan 16, 2013 5:02 pm
What is the difference?
martinz1000r
#6 PostAuthor: martinz1000r » Wed Jan 16, 2013 5:20 pm
HarrisTZ wrote:What is the difference?
Slight difference in shape of the casing at the rear to better blend with the frame but same bolt pattern, clutch action etc
