Headlight dips out momentarily when revving the motor-ideas?
td5_pete
#1 PostAuthor: td5_pete » Thu Feb 07, 2013 9:24 pm
Now I've got my z1000a back together and running, I noticed that when I blip the throttle from tick-over to about 3000rpm, the headlight dips out for a fraction of a second. I thought I was imagining it at first, but with the bike in the workshop and the light shining at the door - it's noticeable and it does it every time. Is this normal ?
It's got the original separate regulator and rectifier, but they seem to be working fine, I'm getting 14.6v to the battery at about 4krpm.
kz1000 custom cafe racer, GPz750 unitrack x2, XJR1200
Paid up club member.
KeithZ1R
#2 PostAuthor: KeithZ1R » Thu Feb 07, 2013 9:46 pm
try a new bulb bit obvious but sometimes !!!! or you may have a break in the wire thats separating at a resonance
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
z1000puddin
#3 PostAuthor: z1000puddin » Thu Feb 07, 2013 9:48 pm
Sounds like a possible bad earth / short. Maybe check the left hand handlebar switch / throttle ??
Zed til Dead
