Z1000A1 Refresher
Mark Stratton
Z1000A1 Refresher
#1 PostAuthor: Mark Stratton » Fri Feb 08, 2013 4:41 pm
Owned this Z1000A1 since 1996. I done a full restoration on it in 1999 but due to various reasons it has not been on the road for the last two or so years. Unfortunately the head gasket has developed a leak and due horrendous problem with damp getting into my garage because of inconsiderate asshole next door neighbours (but that’s another story http://z1ownersclub.co.uk/forum/viewtop ... solicitors) the engine now needs to be completely cleaned and polished.
The rivet counters will see that it is wearing A2 livery instead of A1 but I prefer the A2 colour so thats the way it stays. At the moment :wink: Image
As you can see the damp has played hell on the ally so there's going to be plenty of scotchbrite and autosol in action. Luckily I managed to clear the garage of most of my tools etc so they didn't suffer the same fate.
Idea was to fit some cast wheels, 2:4 seat, straight bars, new paint and just a general refresh by replacing as much as possible with polished stainless etc to give it a new lease of life. I had hoped to replace the valve guides, valves as they didn’t get done last time and fit a hydraulic clutch conversion but as usual the bloody family car has just needed £700 spending on it so the money I had put aside is now diminishing quickly and it looks like its going to be the cheapest tart up possible. More than likely this one is going to be an ongoing project but at least it will be on the road.
Date to aim for I suppose is Sunday 28th April Ace Cafe.
Wheels that I have already bought from another club member, going to get them shot blasted and probably powder coat with polished rims.
#2 PostAuthor: Pigford » Fri Feb 08, 2013 5:00 pm
Those CMA wheels are magnesium (99%) and polishing them is not ideal :??
Looks like a great little project :twisted:
#3 PostAuthor: paul doran » Fri Feb 08, 2013 5:09 pm
that still looks like a very tidy bike
those CMA wheels look brilliant too
zmaxmotorsports
#4 PostAuthor: zmaxmotorsports » Fri Feb 08, 2013 7:35 pm
That neighbor would have my foot print permanently tattooed on his ass,but that's just how I handle things! :lol:
10-72 (build date)z1/2-74 z1s/2-75 z1s/77 1428 turbo/77 1170/78 1170/74 z1 1385 turbo nitrous project/80 1000ltd 1327 z1 clone.........
That ol kaw was fast on the draw
Outgunned suzukis and outrunned the law
zmaxmotorsports
#5 PostAuthor: zmaxmotorsports » Fri Feb 08, 2013 7:38 pm
Did the british version of the a2 get different striping than the American version,or is that just the way you had it done? :wink:
KWACKERZ1
#6 PostAuthor: KWACKERZ1 » Fri Feb 08, 2013 8:05 pm
Note doubting Mr Piggy, but
All the CMA'S i have come accross have been Aluminium not Magnesium, but its worth checking.
If they are magnesium they need to be chromate (or the modern equivalent) coated to prevent bubbling prior to powder coating.
I use http://tpcs-magnesium-refurbs.co.uk/
top notch guy and can do the full refurb and powder coating on wheels.
Might be worth talking to him re the cma's.
#7 PostAuthor: Garry.L » Fri Feb 08, 2013 9:40 pm
Lovely looking thou', just clean her up and leave her as she is!. :wink:
ollie
#8 PostAuthor: ollie » Sat Feb 09, 2013 1:34 am
Garry.L wrote:Lovely looking thou', just clean her up and leave her as she is!. :wink:
totally agree :wink:
gordon62
#9 PostAuthor: gordon62 » Sat Feb 09, 2013 8:38 am
Just get the polish out and keep the cuppa"s coming...... :)
#10 PostAuthor: Pigford » Sat Feb 09, 2013 9:45 am
KWACKERZ1 wrote:Note doubting Mr Piggy, but
You may well be right .... bit I'm sure the set I had n my 1170 Lawson were magnesium :?:
Mark Stratton
#11 PostAuthor: Mark Stratton » Sun Feb 10, 2013 7:47 pm
Garry, might well do at the moment. Just fancy a bit of a change if you know what I mean so easiest way is wheels, seat and bars. Main thing is to put it back onto the road as soon as possible. Anything that I do change will be easily swapped back to standard.
Pigford said;
Pigford this has been discussed before when the seller wanted to know what they were http://www.z1ownersclub.co.uk/forum/vie ... highlight=
Mark Stratton
#12 PostAuthor: Mark Stratton » Sun Feb 10, 2013 9:41 pm
zmaxmotorsports wrote:Did the british version of the a2 get different striping than the American version,or is that just the way you had it done? :wink:
This is actually a US import and as far as I'm aware the paint is how it was when it came into the country. I just prefer the colour and the striping. Plan was to go for something "Z1B ish" using the same sort of red that it is now but as I said thats all gone out of the window due to finances.
With regards to my issues with the neighbour I could not do alot as he was a fully paid up member of the "Jimmy Saville Club" so if you went anywhere near him the police were there in a split second. Funny how these type of people get more protection than law abiding citizens.
Mark Stratton
#13 PostAuthor: Mark Stratton » Mon Feb 11, 2013 10:49 pm
I always like to follow other members projects and have learnt a lot from these. I'm certainly no mechanic but will always have a go at anything so any advise will be gratefully received.
Had a busy weekend so I didn't get much done apart from engine out and top end stripped and checked.
Looks like its been leaking oil into the cylinders 1 & 2, possibly through the stem seals
3 & 4 look okay.
Valves out. It looks as if the inlet valve seals on 1 & 2 are the culprits as there is a good build up of oil around the valve seat.
Although I checked the valves and guides the first time that the engine was apart I can't find the dimensions that I recorded at that time so it's back to measuring it all again
First valve stem diameter and then the stem run-out
Valve guides were next. Only issue I had was my bore gauges only go as low as 8mm.
Picked these up cheap. Not brilliant but good enough to record a decent dimension.
Checked each guide throughout the entire length and measured the gauge with a micrometer.
Don't know if this is the correct method but the manual says that this dimension needs to be checked by "your local dealer", so its the best its going to get seeing as my local dealer went out of business years ago. I'm sure it won't be far short of what a dealer would do however I do stand to be corrected by the experts here who know far better than me.
Inspected the cams and measured the journals and lobes. Got the Plastigauge out to measure the wear on the cam cap bearings. Fantastic stuff and really easy to use.
Pop the cam cap back on and torque down to correct setting.
Remove caps and using the gauge supplied determine what the clearance is on each bearing shell.
Simples
:wink:
If I'm doing wrong let me know.
The following dimensions are valve stem diameter, valve stem run-out, valve guide diameter, cam bearing top & cam bearing bottom. The only one that really concerns me is the inlet 4 valve guide diameter. I may have to go back to this and check it again to make sure that the dimension is correct. As there are no tolerances to go by for the valve guides in the Clymer manual does anyone know if these look okay?
IN 1 - 6.97 - 0.01 - 7.01 - 0.050 - 0.050
IN 2 - 6.97 - 0.01 - 7.01 - 0.050 - 0.050
IN 3 -6.96 - 0.00 - 7.02 - 0.050 - 0.050
IN 4 -6.96 - 0.01 - 7.15 - 0.050 - 0.050
EX 1 -6.96 - 0.00 - 7.01 - 0.050 - 0.050
EX 2 -6.96 - 0.00 - 7.01 - 0.050 - 0.038
EX 3 -6.965 - 0.00 - 7.01 - 0.063 - 0.050
EX 4 -6.96 - 0.01 - 7.01 - 0.063 - 0.050
Cam
IN 24.47 -
IN 24.47 -
IN 1 - 36.29
IN 2 - 36.29
IN 3 - 36.30
IN 4 - 36.28
EX 24.47 -
EX 24.47 -
EX 1 - 35.79
EX 2 - 35.79
EX 3 - 35.79
EX 4 - 35.77
Cams all seem to be within tolerance and no signs of wear.
Run-out on head and barrels was a bit hit and miss as I don't possess a decent 18 inch straight edge. I borrowed our calibrated test square from work but it is only 14 inches long so I couldn't be sure on this one. Is there anyone in the Southampton area who has one that I could borrow?
The edge does rock on the cam chain tunnel in the centre and creates a gap large enough for a 0.051 feeler blade to pass under when checked at one end. The two individual sides of the head are completely flat so it is just the issue with the centre. Can I get away with this amount of warp/run-out or does it need to be skimmed?
HEAD 0.051 -
CYLINDER 0.00 -
Wiesco 1075 fitted. Bores seem okay as well to these dimensions.
1 72.01 - 71.97
2 71.98 - 71.99
3 71.98- 71.97
4 71.98 - 72.00
ollie
#14 PostAuthor: ollie » Wed Feb 13, 2013 2:33 pm
excellent images mark ,there should be quite a few zed owners down your way who can give you good advice .Or ring debbens at ringwood ,they are always helpful . :wink:
Mark Stratton
#15 PostAuthor: Mark Stratton » Thu Feb 14, 2013 1:58 pm
I must admit ollie the initial idea was just to take the head to Debbens and let them change valve guides, put new valves in it, skim, heli-coil spark plug threads etc and generally sort it all out but cash flow not allowing now means that I've got to try and complete it for as little as possible. I may take a trip to Debbens just to get his advise on the warp and if it needs a skim. Good excuse to sample some Ringwood Brewery beers whilst I'm in the area as well.
