KAWASAKI Z1 ENGINE GASKETS
note the last number of each part number is the quantity required
example 11004-1295 2 = 2 required
example 92049-016 8 = 8 required
GASKET/ CYLINDER HEAD 11004-1295 2
GASKET/ CYLINDER BASE 11004-1269 1
GASKET/ GENERATOR COVER 11061-1082 1
GASKET/ POINTS COVER 11060-1594 1
GASKET/ R/H ENGINE COVER 11061-1129 1
GASKET/ TRANSMISSION COVER 11060-1531 1
GASKET/ CLUTCH COVER 11060-1529 1
GASKET/KICK START COVER 11060-1606 1
GASKET/CLUTCH ADJUSTER COVER 14045-015 1
GASKET/ SUMP COVER 11061-1120 1
GASKET/ CAM CHAIN TENSIONER 11009-1980 1
GASKET/ CAM COVER 11060-1605 1
KAWASAKI Z1 ENGINE SEAL'S & O RINGS
SEAL/ GEAR CHANGE 92049-004 2
SEAL/ GEARBOX 92049-1506 1
SEAL/ R/H ENGINE COVER 92050-047 1
SEAL/ CLUTCH PUSH ROD 92050-048 1
DAMPER RUBBER / CAM CHAIN ROLLER 92075-122 4
DAMPER RUBBER / CAM CHAIN ROLLER 92075-123 2
SEAL/ OIL GAUGE CLUTCH COVER 52015-004 1
SEAL/ KICK START 92049-1048 1
SEAL/ VALVE GUIDE 92049-016 8
O RING/ OIL FILTER COVER 671B25105 1
O RING/ OIL PUMP 92055-048 3
O RING/ SUMP/ BREATHER COVER 92055-052 2
O RING/ OIL FILTER BOLT/ SUMP DRAIN BOLT 670B2022 2
O RING/ CYLINDER LINER 92055-054 4
O RING/ OIL PRESSURE CASTING 670B2018 2
O RING/ OIL PRESSURE CASTING 92055-055 1
O RING/ OIL BREATHER BOLT 760B2016 1
O RING/ OIL FILLER CAP 92055-049 1
O RING/ ENGINE BLANK PLUG 670B2015 1
O RING/ TACHOMETER 670B1510 1
SEAL/ TACHOMETER 92050-075 1
SEAL/ CYLINDER HEAD HALF MOON 92066-017 4
CIR CLIP/ PISTON 92036-021 8
USEFUL PART NUMBERS FOR Z1 ENGINE REBUILDS
Users browsing this forum: Bing [Bot] and 69 guests
