ZZR1100 wont run off choke
Ok, i need my ZZR1100 out the shed so i can get the Z1000 J on the lift, problem i have now is she started up fine about 6 weeks ago, come to start it up ready to take it for mot and it will run and rev up on choke but as soon as you start taking choke off she cuts out, just like you have a main jet blocked.
Now i cant have all 4 jets blocked at same time, fuel pump works fine, there seems to be a smell of unburnt fuel, so thinking the igniter is at fault. There is a spark when testing on plugs when just flicking it over on starter.
Anybody got any ideas??
Cheers to all.
Cheers to all.
Ok, well it still wont run right, have now got a new battery on it, new spark plugs and fresh fuel, it is on an auxillary tank at moment, just so i can see what im doing. I have also changed the igniter for another i have, no differance and also swapped ht leads and coils for some others i have, also no change.
Looks like carbs are going to have to come off and stripped down, but i just cant see how all 4 carbs can fault at the same time.
Does anyone else have any other ideas??
Getting one desperate dude.
- Mark Tiller
http://www.zzr-international.co.uk/view ... 12&t=11262
I am not familiar with your bike, but this post has a couple of ideas
