Dyna s pick up wires
stempy
#1 PostAuthor: stempy » Fri Mar 01, 2013 7:40 pm
dyna s pick up wires, outer covering is cracking, can you get spares for Dyna S as I would like to renew the wires from the pick up coils up to the ignition coils :?? :??
PUM 451
Garn 1
#2 PostAuthor: Garn 1 » Fri Mar 01, 2013 7:47 pm
Are you talking about the insulation on the low tension wires? ..... They are usually just ordinary auto wire of a set amperage readily available.
RegardZ.
Ps.There is usually a join between the pick-ups and the coils
