50mm USD radial Fork Question
Royalratch
#1 PostAuthor: Royalratch » Sat Mar 02, 2013 8:29 pm
I've got these forks from a 2006 Ninja ZX6R.
My callipers measure the clamp diameters at 50mm top and 52mm (52.12mm)at the bottom. Is this correct?
As I want to change them for a slightly different set from a 2011 GSXR but the seller says the bottom clamp diameter is 53mm.
Anyone shine a light?[/img]
garyd
#2 PostAuthor: garyd » Sat Mar 02, 2013 10:58 pm
Sounds about right...the bigger the bike, they like to make the forks thicker...for bragging right I guess.
I'm fitting a set of Superduke forks to mine and they measure 60mm
garyd
#3 PostAuthor: garyd » Sat Mar 02, 2013 11:01 pm
Just checked my list of fork sizes...don't have the 2011 GSXr but here's some older ones.
Top BTM
K1 GSXR1000 50 54
K2/3 GSXR1000 50 54
K4/5 GSXR1000 50 54
Royalratch
#4 PostAuthor: Royalratch » Sat Mar 02, 2013 11:19 pm
Damn.
So they do appear to change from by a few mm here and there.
I assume these forks are all made bu Showa for all the different Jap makers - why change the leg diameter? Some of the GSXR forsk are even 43mm at the clamp.
Aaarrgghh.
#5 PostAuthor: Ginger Bear » Sun Mar 03, 2013 11:57 am
This might help.......
I originally found this on the oldskoolperformance site, although the chart I have posted is an updated version.
More info here..... http://www.oldskoolperformance.com/foru ... =10&t=1659
Royalratch
#6 PostAuthor: Royalratch » Sun Mar 03, 2013 1:32 pm
Thanks dude.
No confirmation on 05/06 ZX6R fork diameters tho.
Maybe my digital calipers are not accurate? Doubt that tho...
Crofty
#7 PostAuthor: Crofty » Wed Mar 13, 2013 11:33 am
Hi Ratch, I thought you had it all sorted with those nice yokes, why do you want to change to the Suzuki forks? Jim
