A few bits required just to get me started...
zpower
#1 PostAuthor: zpower » Sat Mar 16, 2013 4:08 pm
Hi all,
I'm hoping you guys can help me out with a few bits for my initial blind build.
Right my project / challenge is a Z1000 A1 engine into a GPZ1100 A2 frame with Z1 paintwork and a ZX6R swinging arm. That's all I have at the moment.
First off cosmetic condition of the parts is unimportant as all will be replaced or re-chromed or whatever but I need a basis to start from for my blind build.
If anyone has any of the following please let me know :-
Engine mounting kit the condition is unimportant as new parts will need to be fabricated to fit the GPZ1100 A2 frame but I need a basis to start from. In fact if you don't want to sell one but wouldn't mind loaning one out for a few weeks that would suit me fine also :)
Kickstart as the current plan is not to have a starter motor
Z1 oval rear light
A set of exhaust clamps preferably the Z1000J type or even just one so that I can copy it
I need a set of carbs as cheap as possible
ZX6R / ZX9R / ZZR1100 or similar rear shock
That should be enough to get me started.
Many thanks,
Phil.
garyd
#2 PostAuthor: garyd » Sat Mar 16, 2013 5:01 pm
I can loan you a set of 1100 unitrak mounting plates and bolts.
Z1parR
#3 PostAuthor: Z1parR » Sun Mar 17, 2013 10:34 am
0172 . Geoff Parr
