I complete the installation of the rear fender but I realized that I missed to install the two rubbers with number 92075-135.
From the drawing is not clear where I should fit them.
Any help?
z1bman wrote:THEY FIT ON THE INSIDE OF THE FRAME AT THE REAR WHERE THE INDICATOR MOUNTING BRACKET IS WELDED TO THE FRAME. THERE ARE TWO SMALL SQUARE MOUNTINGS WELDED TO THE FRAME WITH A HOLE IN THE MIDDLE + THE RUBBERS ARE FITTED THERE TO PREVENT THE REAR FENDER MOVING BETWEEN THE FRAME WHEN FITTED THEY WILL MAKE THE MUDGUARD A TIGHT FIT IN THE FRAME
Users browsing this forum: No registered users and 105 guests
