Smooth bore what jets,clip setting
I am getting ready to install a set of 29 mm smoothbores with pods to the z. The bike is stock except for a V&H 4 into 1. I have a friend who insist I put the needle on the #4 clip and run 120 main jets. Is this Ok ?? Your opinions will be helpfull.Thanks gregz
Z1
1965 Corvette
1965 Corvette
- Jeff Saunders
Do you know what the 29's came off? If they came off a Suzuki, then the slides may have 2.0mm cutaway versus the 1.5mm normally found on the zeds.
Assuming you have the 1.5 slides, I would normally start with 120 main jets, 20 pilot jets, needle clip in the middle (number 3 position) and the air screw 1 1/4 to 1 1/2 turns out.
#4 clip setting is a little rich and it will probably be a little too rich for a stock setup with V&H pipe.
Users browsing this forum: Bing [Bot] and 86 guests
