The ZPower Project
zpower
The ZPower Project
#1 PostAuthor: zpower » Fri Mar 22, 2013 1:22 am
Hi all,
The project is based around a GPZ1100 A2 frame.
The engine is a Z1000 A1 (1977)
The idea (Plan A) is to build a vague silhouette of a Z1 but mono shocked so I will be using Z1 paintwork etc...
The plan is to only modify the frame to accommodate the project requirements so everything else can be readily bought of the shelf and therefore more easily upgraded at a later date.
Not surprisingly none of the paintwork currently fits in any shape or form.
I slipped (well not quite but hey ho) the frame over the engine to see what initial mods needed doing...
The first immediately obvious obstacle was the rear suspension mounting bracket which is stopping the engine from dropping in. It also gets in the way of the ZX6R swinging arm.
It is to late to start on it today but I have some micro adjusters at the ready... :D
To be continued....
zpower
#2 PostAuthor: zpower » Fri Mar 22, 2013 8:28 pm
First tentative micro incisions made :D
The engine now sits in the frame and initial look at the swinging arm and tail piece fitment...
Swinging arm clears JUST :D
Top down view of just how close things are...
Then engine can move a little further forward but can't line anything up just yet.
Happy so far :D
garyd
#3 PostAuthor: garyd » Fri Mar 22, 2013 9:25 pm
Really interested how this goes as I have a very similar project in the garage.
I have had ZERO luck in getting any tank to fit.
best effort so far was to completly screw up a Ltd tank by taking a lump hammer to the inside
Just cant find anything that will fit the wider frame tubes at the rear of the tank.
Next effort is to cut out the inner of a GPz tank and try to mate that to a tear drop outer.
I can only see tears comming from that. !!
#4 PostAuthor: kev edwards » Sat Mar 23, 2013 10:50 am
garyd wrote:Really interested how this goes as I have a very similar project in the garage.
have you thought about a zephyr tank?
oldtimer
#5 PostAuthor: oldtimer » Sat Mar 23, 2013 11:01 am
Have you tried to find a second hand Zephyr tank? Like rocking horse s*%t ! :shock:
dixiethedog
#6 PostAuthor: dixiethedog » Tue Mar 26, 2013 2:34 pm
Nice project. Ive a gpz750 uni trac that Im going to fit z1 panels too.
Fitting the tank is a peice of cake,if you have a welder?
Simply copy what has been done in the link. :D
http://www.oldskoolperformance.com/foru ... 8&start=14
i tried to fit a different tank to a frame that didnt want the tank to fit (Im not sure what bike it was now?),with a hammer to the base of the tank. :roll: Never again! Frames are lot easier to modify!
Good luck. :D
Every silver lining has a cloud...
garyd
#7 PostAuthor: garyd » Tue Mar 26, 2013 6:46 pm
The 750 Zephyr looks most like the Z1 tank, but your right...just don't come available unless they have a dent in...even thought about buying a bike and selling off all the other bits...but they still go for £1500..too rich for me!
I'm sure I can make this Plug'N'Play...just need to keep doing my research.
garyd
#8 PostAuthor: garyd » Tue Mar 26, 2013 6:52 pm
That's too serious a mod on the frame for me...I do have a habit of 'finding the limit' of bikes chassis :lol: :lol:
dixiethedog
#9 PostAuthor: dixiethedog » Wed Mar 27, 2013 9:40 am
Cutting a couple of frame tubes is a lot easier than trying to weld the base of a diffferent tank in with the chance of fuel leaks. But good luck to you Gary! lol.
Just get the grinder out and cut the frame!!!!!!!!
zpower
#10 PostAuthor: zpower » Fri Sep 06, 2013 2:04 pm
Hi all,
Sorry it's been so long but my account was foo barred but Taffus has now sorted it for me.
Right lets have a look at getting the Z1 tank on the GPZ1100 A2 frame.
First do some measuring then a couple of micro incisions in to the old bent frame and remove side rails from the GPZ frame.
Vuala...
A couple of bits to trim off the GPZ frame and tidy.
Right ready for welding.
** Special rates for the Z1OC forum members **
Website design, hosting / domain names.
Computer and Laptop repairs.
Jay1969
#11 PostAuthor: Jay1969 » Fri Sep 06, 2013 4:44 pm
This is awe-inspiring, looking forward to seeing more progress.
Just like to say thank you to Z-Power for the replica Z1 body kit I bought
from their online store recently, very pleased with it :up
#12 PostAuthor: paul doran » Fri Sep 06, 2013 5:01 pm
Your a brave Man cutting a frame as You have
coldsummer
#13 PostAuthor: coldsummer » Fri Sep 06, 2013 5:51 pm
This looks really interesting, looking forward to seeing how it turns out.
My Z1b had the fuel tank 'widened' to accommodate some chunky top tube braces but I guess altering the frame is another option.
zpower
#14 PostAuthor: zpower » Sat Sep 07, 2013 4:31 pm
Ok done just a bit of tidying up to do :)
With the tank on...
And what it looks like fitted...
It all appears to have remained straight but I will be getting it jigged up and tested when I have finished by the guru known as Martin Russell. He did loads of our one off stuff for our Harris's back in the day including straigntening a few of our frames he he :)
He did the yoke conversion for me ZX6R on to GPZ1100 stem.
Next on the agenda is the rear suspension line up and welding :)
sanderz
#15 PostAuthor: sanderz » Sun Sep 08, 2013 8:39 am
Liking this, keep us posted on your progress :up
Just a thought - have you tried the 'lock' now the front end is in, and the tank is on?
I know others have moved the tank locations back slightly (10mm or so but be aware of the tap fitment) to achieve more lock. Easier to do it now and alter 'lock stops' / tank mounts at this stage. Like I say only thinking out loud here ......a grown up will correct me here im sure.
Wots up DOHC
