Thanks!
Clutch is slipping
Clutch is slipping
Talking about my KZ700.Again... Is the 700's clutch interchangeable with other model's?It is slipping especially when cold.When engine warms up seems to be better but will slip at higher revs.Can it because of the oil?
Thanks!
Thanks!
Maak
Try 10/40 mineral: there's some previous debate on the forum about which "brand" to go for, ranging from your Tesco / Halfords own label, to the posher stuff. I used Castrol ACT evo mineral - which cured the dreaded slip on my A4.
